Yellow sludge under oil cap?
Old 11-28-2009, 02:55 PM
Donohue96M6Z28's Avatar
Default Yellow sludge under oil cap?
I just noticed this... any ideas?
Old 11-28-2009, 03:07 PM
sabastian458's Avatar
um that looks like some major water contamination in the oil. I know a slight amount of yellow under the cap is "ok," but that isnt slight. I would check your oil and or drain it to see if there is any more in the pan quickly
Old 11-28-2009, 03:08 PM
Breathing Fire's Avatar
That is I belive, and I don't pretend to know a lot, but I think that is moisture in the oil. Happens if you do a lot of short trip driving. Might be wrong tho. My old 97 had that start happening when I only worked a few blocks away from where I lived at the time.
Old 11-28-2009, 03:09 PM
outkast6991's Avatar
that would be moisture from the oil. no big deal. lots of short trips where the motor doesn't get hot enough to burn it off.
Old 11-28-2009, 05:16 PM
ae13291's Avatar
that is from short trips for sure. but check the oil it could be bad enough for a headgasket if you see that on the dipstick
Old 11-30-2009, 04:11 PM
jmm98LS1's Avatar
Every year about this time several threads like this pop up....cold temps + oil not getting hot enough to burn off condensation.
Old 11-30-2009, 07:31 PM
cutlass_455's Avatar
+ 1 to the short trip thing. Also, give your PCV system a once over, change the PCV valve to make sure its functioning properly.
Old 01-15-2010, 01:56 PM
attilahooper's Avatar
I haz that in the LT1 fleetwood. Just doing a much neglected oil and filter change and said to meself; "wtf self ?!?!?!!".
Old 01-15-2010, 07:27 PM
SLP Firehawk's Avatar
its just condensation from short trips like you were told above it doesn't mean your oil is bad. just try and take it on a long trip to evaporate that moisture.
Quick Reply: Yellow sludge under oil cap?
