Best/Safest Valve Springs for cams with...
.590-.610 lift? Which are the better working and more reliable springs? The rev duals or the iskey(which I believe are single)? This will be for a car that is a daily driver around 75 miles on it a day.
Thanks
Thanks
Originally Posted by Goober
So basically for the larger cams with high lift, the iskys are out of the picture?
LS1Tech Premium Sponsor
We run the Crane Duals with Titanium retainers, they're considerably less expensive than some of the other options & are good to 650 lift
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason
Jason
Originally Posted by 9secbird
so will you have to change these all the time since he will drive it everyday? just wondering cause im going to do the same set up, im wanting to go with the 232/240 591-602, but i also will drive everyday for now, and i dont want to change valve springs evry six months either
Sean Freese, owner of MMT, has told me he uses the isky single tool room spring and has had great success with it on his high lift .600 lift Ls1 cams. He also stated that its the same design isky spring that Nascar runs. Also, a vette customer of his running a huge .625 lift cam in his stroked z06 (4.125 stroke) has about 90 dyno WOT pulls and countless WOT driving situations without an issue with the isky tool room spring.
That being the case, it seems like a GREAT SPRING, but i also would feel safer having the extra protection of a second spring to avoid a dropped valve and MAJOR DAMAGE, etc.
I would go with the Crane duals.
As for spring life, it all depends on how much you rev the hell outo f the motor. If you're just driving every day at normal throttle and only hammering it once in a while, spring life should be excellent. But, if you're driving the car with your foot in it all the time, then the springs won't last long.
Spring life is determined by the quality of the springs, how close to coil bind they are run at, and how hard you run the engine.
