Scat I-beam rods
Old 12-03-2009, 07:18 PM
1fastkingcab's Avatar
Default Scat I-beam rods
I was planing on running stock LS1 cracked rods, with ARP or KATECH rod bolts, but after pricing the hardware and machine shop costs to hone the stockers with the new hardware. I'd only be about $100 away from getting the foraged Scat I beams.
Here is a link to the SCAT rods http://www.summitracing.com/parts/SCA-26100927/
would it be money well spent?
Also I already have my pistons, and my block is already honed for my pistons so I REQUIRE a stock length rod, I also have seen K1 H-beam rods in the stock length for about $200 more than the Scats, but I haven't heard anything about K1
Thanks,
Tom D
Old 12-03-2009, 07:24 PM
Oh and the motor is an iron 6.0L .030 over with Mahle flat top pistons. I'm hoping for 500~550hp at the crank with heads & cam. It's going to get sprayed from time to time, not sure how much I guess it depends on my weakest link. I figure if I keep the stock rods they will be the weak link.
Old 12-03-2009, 08:26 PM
KCS
Moderator
KCS's Avatar
Thanks,
Tom D
I say go for it, looks like a nice piece. 4340 steel, 7/16" capscrew, bushed pin. Looks good.
Old 12-03-2009, 09:03 PM
1989GTA's Avatar
Lot of good reports about the Scat forged I-beam rods.
Old 12-04-2009, 12:06 AM
Mike@ZMS's Avatar
PM Inbound
Old 12-04-2009, 12:20 AM
sandragnx's Avatar
Hey,before you buy those scats,I've got a set of manely I beams that look just like those and are also stock lenght.They are used but in perfect condition and you can have them for half the price of those new scats.I can get pics this weekend if you want.
Old 12-04-2009, 04:35 AM
So the scat peices are deafinatly an upgrade over the stock rods.
Old 12-04-2009, 07:24 AM
1969mach1's Avatar
Most anything will be an up grade over the stock powder metal rods.
I would take Sandragnx up on his offer, Manely rods are great.
Old 12-04-2009, 01:37 PM
jmm98LS1's Avatar
I run those Scat I beams in my 370. Have put them through ~675rwhp and 7500rpm.....definitely a great upgrade for the money!
Old 12-04-2009, 03:48 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
When you are looking for rods not all are the same even though they say LS on them. Make sure the PIN dia will work with your rod/piston combo. Unless you are using .927 small pin on your mahle pistons, then you can use those. otherwise its a diff part number.
Old 12-04-2009, 06:30 PM
and I'll bet thats what screws me out of sandragnx's manleys. When I bought my pistons I was planning on using the stock rods, so I got them with the .945 pins
Does anyone make an affordable 6.1" rod for the larger pin?
Old 12-04-2009, 09:35 PM
I found SCAT part # 2-ICR6100-944P which is the same rod as the one I posted a link to, but designed for a Pressed .944" pin. Can I use a rod designed for a pressed pin with a floating pin piston? It looks like the .927" rods have a bushing in the small end and the .944" rods do not.
Old 12-05-2009, 12:06 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
you just have the rod bushed.
Old 12-05-2009, 12:07 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
scat has an H beam as well. its not much more and is a floating pin .944
Old 12-05-2009, 01:12 PM
I saw the Scat H beams, for the .944" pins P/N# 2-LS1-6100-2100-945
I don't want to have some over the top rods if my pistons or rings or crank are only mediocre at best. if that makes sense.
Old 12-07-2009, 09:18 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
H beams are not over the top.
Quick Reply: Scat I-beam rods
