Question on cam size for 5.3L
I got a 1999 5.3l in my 1996 pickup. Im lookin to put a cam in it with my next paycheck. i want to put the biggest cam i can put in it without haveing to change anything else. My limit to spend total is $500.
Put that $$ in a place you cannot touch it. Save another similar amount then pull the trigger.
Why? Because along with cam you'll need supporting hardware: (springs, timing chain, pushrods, fluids, gaskets and of course tuning)
I would need way more info than this to know which cam would fit in your parameter setup, but right of the bat I would say no on the LS6 cam due to the size of your turbo.
To make these numbers, I would be looking at a bigger cam than LS6 and with some overlap. I cannot be more specific without complete combo info including specific turbo info. In brief the whole enchilada from front to back bumper including weight etc....
Read around the FI forum and dyno forum a bit, you'll get more info and get a clearer idea.
