Milling 243 heads w/ nitrous???
I'm having a set of 243 heads worked over this winter. My plan is to have them milled .030" and use stock .051" gaskets. Should put my CR around 11.2:1.
I've been toying with the idea of spraying the car, but I want to know if my deck height will be too thin to spray.
What is the deck height limit when using nitrous? When do I need to go from bolts to studs?
Educate me please...
N2O can be used with compression ratios as low as 9.5:1 and as high as 15:1 its all about the set up. What you have to make sure is that you are using the correct equipment. Like ARP Studs/bolts. Also that your fuel is correct and you are running the correct timing. Many cars have milled .030 and are using N2O.
Good Luck
Good Luck
Good Luck
Good Luck
