What head gaskets? 317s on ls1
Old 12-09-2009, 03:13 PM
XtremeDime's Avatar
Default What head gaskets? 317s on ls1
I have a stock bore LS1 and I just picked up some stock 317 heads. Which head gaskets do I need? Im thinking its the GM #12589227 but not sure.
Old 12-09-2009, 03:16 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
http://www.texas-speed.com/shop/item...d=880&catid=36
That'll do the trick!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-09-2009, 03:40 PM
XtremeDime's Avatar
Thanks alot Matt! Also can I reuse the stock head bolts?
Old 12-09-2009, 03:47 PM
BadgeZ28's Avatar
No on the head bolts. The stockers are stretch to yield and should only be used once.
Old 12-09-2009, 03:49 PM
XtremeDime's Avatar
Thanks, Ill get some new ones too.
Old 12-11-2009, 02:19 AM
Mighty-SS's Avatar
Originally Posted by Matt@Texas-Speed
He is right, always match the gaskets to the heads (or whatever is bigger, in this case the heads)
Old 12-11-2009, 02:21 AM
Mighty-SS's Avatar
Ohhh and get some ARP Head Bolts so if you change heads later you can reuse them
