New Cam Specs
Old 12-10-2009, 06:05 PM
highway21's Avatar
Default New Cam Specs
just ordered my custom cam from Pat
235/243 .621”/.624” 111LSA +4 advance.. matching it up with untouched ls6 heads and fast intake.. wish me luck with the big numbers
Old 12-10-2009, 10:00 PM
zacht's Avatar
oh hell yeah man! im subscribing to see some numbers!
Old 12-10-2009, 10:09 PM
printmanjackson's Avatar
what are the goals with this?
Old 12-10-2009, 10:40 PM
highway21's Avatar
ya will keep it updated, dropped the heads off to get some valve work done.. iono if a 5 angle valve job is worth the money but every bit helps i guess..my plans and goals for this setup is to be low 11's high 10's with a 9" and 4:10 gears. well when i get the 9".. all motor. will port the heads when i get more money, but as for right now they should be more then enough.. and who know, maybe in the future i will spray :-)
Old 12-10-2009, 10:43 PM
highway21's Avatar
really would like to see 450+ (rwhp) all motor, but that might be asking for too much.. crossing fingers! just ordered hp tuners, so going to do a race gas tune so i can squeeze every little bit out of this stock block i can.. then have a 91 tune for daily driven
Old 12-11-2009, 01:08 AM
DSkyles's Avatar
There is no point in running race gas unless you have a higher compression that calls for it.
Old 12-11-2009, 02:23 AM
highway21's Avatar
well it will let me advance the hell out of my timing. like i said just to give me that extra edge against the other guy. trying to get as much as i can out the motor.
Old 12-11-2009, 12:38 PM
zacht's Avatar
yeah for sure a race gas tune is more agressive than a 91 octane tune.
if you dont mind me asking what kind of setup is this thing? and what kind of powerband is it designed for? this is something close to what i want to run with prc 243 stage 1s/duals and LS6 intake. only thing i would change for my setup is go to a 112-113LSA to kill off some of the lope. thats just for me tho
Old 12-11-2009, 05:44 PM
MASS seller approved
smok'nZ's Avatar
i think your gonna need some weight reduction so see your 10 sec pass na
sounds like a healthy cam
Old 12-11-2009, 06:03 PM
sprayedenali's Avatar
should at least sound good!
and im sure it will perform just as good! good luck with the numbers and time
Old 12-11-2009, 08:25 PM
outkast6991's Avatar
if you do some searching there are a few good threads on "aggressive tunes". some of the hardest running N/A setups use alot less timing than you might think. some run less than 26 degrees on an efficient setup. timing isn't gonna be the savior some might think
Old 12-11-2009, 09:18 PM
highway21's Avatar
setup is for ls6 heads/fast intake/stock gears/6speed/3500lb car.. and might spray in the distant future. the power band should be in the higher rpms, but the cam is advanced to bring it down to more mid range.. so it isnt a pig in the mid rpms.. should have a nice curve i hope, only the dyno will tell
Old 12-11-2009, 09:21 PM
highway21's Avatar
just got done doing a full UMI front end package.. tubular k member, upper and lower control arms.. no ac pump, no power steering with a manual rack. should have shed a few pounds right there..
Old 12-11-2009, 09:33 PM
disc0monkey's Avatar
imho i believe you will need to mill those 243 heads a bunch to benefit from race gas.
Old 12-11-2009, 09:37 PM
highway21's Avatar
oh i know timing isn't going to make my car gain crazy numbers.. just trying to squeeze as much as i can out of it. and a race gas tune should get me closer to my goals then a 91 pump tune.
Old 12-11-2009, 09:43 PM
FiredUpZ28's Avatar
I don't think your gonna gain much if any top end by advancing the timing. You need to retard it back down when you get past your midrange.
Old 12-11-2009, 09:44 PM
highway21's Avatar
well i know the 243 heads raise compression a lil more then the stock 241's.. so its already getting a lil more compression from the get go. then if i mill the head will raise compression even more. would like to spray in the future, and i know some higher then stock compression engines run nice on the juice.. but thats with a worked engine with at least forged pistons.. never sprayed a stock block ls1 b4.. but i know my lil 302 5.0 loved the stuff, sprayed a 150 and it asked for more. if i was running a standalone fuel setup, how much juice could this lil engine handle with the appropriate head studs and head gasket?
Old 12-12-2009, 11:18 AM
yeah just letting you know you should look to mill the heads. Get your DCR on the upper limit of 93. thats where mine is. i know with some racegas and n2o, it will go apeshit.
Old 12-12-2009, 08:07 PM
CUR 4 VNM's Avatar
cant wait to see this thing running around with a cam. are you going to quite that exhaust down though?
Old 12-12-2009, 08:39 PM
highway21's Avatar
i would hope so haha
