cam install questions
Old 12-11-2009, 10:28 PM
MIKEY'S 2002 TA's Avatar
Default cam install questions
hi,
i have a 02 trans am and want to get a cam installed. how much should i be looking at to get a cam installed??
Old 12-12-2009, 03:01 AM
nightmare23's Avatar
u mean labor?? depends on shop ..
Old 12-12-2009, 09:21 AM
BrownBoy's Avatar
Its a fairly straight-forward installation and there are quite a few write-ups avaliable online. You'd save a lot of money doing it yourself and the labour will vary from shop to shop.
If you don't feel comfortable doing the installation, call around to a couple shops near you and see which one you like best. Good luck!
Old 12-12-2009, 01:31 PM
98z8uup's Avatar
Yes there are some write-ups on this, but alot of them don't give you a lot of the small details you may need to get everything just right. You can do like (BrownBoy) and call some shops near you. Good luck!
Old 12-12-2009, 01:40 PM
98z8uup's Avatar
Use the search. This ? has been ask.
Old 12-12-2009, 02:14 PM
Default cam install
thanks for the replies
Old 12-12-2009, 07:13 PM
hcb1700's Avatar
You should do it yourself, and it is a pretty straight forward process. Get you a good manual and do it, an if you have any questions, that's what the forum is here for. Good luck.
Old 12-12-2009, 08:35 PM
10 Second Fun Car
jlrz28's Avatar
This is the one I used. It was very straight forward.
http://www.ls1howto.com/index.php?article=23
Old 12-12-2009, 10:59 PM
2000TransAmWS6's Avatar
that website has very good instructions, i just suggest reading through them before you start so that you will know what to expect and what you will need.
also, having the right valve spring compressor is ESSENTIAL!
i've done the job a couple of times and its not too bad if you take your time, you should give it a try!
Old 12-13-2009, 01:11 AM
well if u dont have the right tools its going to be a pain .. ive done quite a couple of cam swaps recently and they go smooth with the correct tools... try seeing if any sponsors can help u out with an install
Old 12-13-2009, 04:16 AM
MJs1FastSS's Avatar
^^^^ could not agree more
Old 12-13-2009, 05:05 AM
khaotic's Avatar
Default Cost
If you looked at book time that a shop may charge is 9.1 hour going by book time so it could range from $750. to $1000. for just the cam install then you have fluid $36.86 Dexcool, Oil and filter $64.93 synthetic oil remeber these are shop prices they cannt stay open for free LOL then theirs the gasket kit new harmonic balancer bolt, valve cover gasket, timing cover,then depending on the cam you have valve springs $265. then the install on them $250.
But those are the prices that I see from Richmond Va to Nothern Va area, and you may also get into other cost if they find the timing chain is **** thats another cost just things to think about then you have the tuning everything from a mail order tune of $149 plus shipping overnight cost are about $68 I think round trip to a tuning shop $440. to $500.
Then one of the main differance that you will see from a do it yourselfer to a professionl shop is that they degree the camshaft where most do not. theirs alot more involved and liability when a shop does it verses yourself if you break it its your NICKLE if a shop @#$% up then it on them or if it doesnt run and so on
Old 12-13-2009, 05:44 PM
eallanboggs's Avatar
Compared to an engine with multiple overhead cams(up to 4) and miles of chain this cam swap is a breeze. Neither the intake or heads have to be removed. If you do the swap yourself(labor costs) you can buy all the special tools to do an LS series cam swap and have money left over. Then you still have all those tools in your tool box ready to do another LS cam swap. What a deal. Most people set the cam and crank DOT to DOT. If you're going to degree the cam you need an adjustable timing set to fine tune the cam/crank relationship. Most people don't install adjustable timing sets altho there are some available(Rollmaster, Cloyes, Jesel). Do it yourself and don't forget the Vinci/Crane tool. Best $100 you'll ever spend.
Old 12-13-2009, 05:55 PM
Default cam
thanks for the replies. my mechanic said it will cost me about 2,000 to put a cam in. that's the cam, springs,push-rods and labor. does that seem fair or a bit to expensive??? let me know what you think. thanks
Old 12-13-2009, 06:12 PM
Spd-Kilz's Avatar
That is absolutely ridiculous.
I don't think shops charge that much for heads and cam installs.
I'd try a few more places. $2000 is unreal.
Good luck!
Old 12-13-2009, 06:20 PM
Default cam
hi, the 2,000 included the cost of the parts also. is that still to expensive?? let me know what you think.
Old 12-13-2009, 06:49 PM
$2,000.00 including parts? That's well over $1,000.00 in labor. Sounds like a bargin to me. It's only money. Why get your hands dirty when you can pay someone else to do it. Don't listen to the guys on this site that tell you to do the cam swap yourself. They don't have any idea of what they're talking about. It's your car and your money and if you what to overpay to have a cam swap done why shouldn't you be allowed to do it? Tell those grease monkeys who think it's OK to do their own work to keep their opinions to themselves.
Old 12-13-2009, 06:52 PM
jimmypop13's Avatar
yeah that's too high.
Down here at a professional shop it's around $1800-$2000 for the cam, pushrods, dual valvesprings, dual timing chain, all gaskets/bolts/fluids, install and a full dyno tune. Around $800 more for ported ls6 oil pump, bigger fuel injectors, and an underdrive pully installed
Old 12-13-2009, 06:53 PM
jimmypop13's Avatar
Old 12-13-2009, 06:54 PM
Default cam
thanks guys. its way to high. i appreciate the input.
Quick Reply: cam install questions
