Has anyone ever slipped a stock sleeve?
We started looking more into what could have been the cause of my coolant consumption this weekend and finally think we nailed it. we were looking at the head gasket and noticed that on the #7 cyl the graphite was burned off all the way to the steel ring on the gasket from the little holes that allow water to pass through the gasket. While I was busy inspecting the gasket my buddy reaches in to the block and drags his finger nail accross where the sleeve meets the block and it snagged. it looks like the stock sleeve has slipped in an upwards direction.
How often does this happen? and what could have caused it. We are going to take a closer look with some gauges this week to confirm the slipped sleeve, but if thats the problem........... . Looks like its time for a new short block.
TIA
NATASS
TIA
NATASS
There is really noway you can drop a sleeve on a stock block. The sleeve is cast in. If you look at the back of the sleeve you will see probably 40 plus grooves that the cast aluminum forms into whe it is pored. For the sleeve to move, you would have to shear all these bond points to shift the sleeve, which is vertually impossible.
Shaun (valvegod@aol.com)
Eric - Noone cracked a stock sleeve in his car about 2 years ago and ARE was able to replace and re-sleeve the block with no problems.
He was running NO2 at the time and was dynoing the car. When the operator hit the button the charge backfired and melted a slug cracking the cylinder wall.
They can be repaired quite easily.
Paul
Paul
