Cant decide if i want to do heads also
Im wanting to mod my car over the winter. Been toying around the idea of just spraying the car and saving a little money that way. But i want to power all the time. I have a 2000 LS1 with the 853 heads and was going to do cam only. Do you guy think its best to go ahead if i can swing the extra $$ to upgrade the heads? Im wanting to run some 6.70 1/4 10.60 1/4. Put know if i thats going to run me $2000 with heads and cam. So i guess im looking for some head and cam suggests OR just go spray and be happy?
Only way to get around some of that is with major weight reduction, I have been down that road and won't do it again.
For what you want for the amount of money I would buy a used 9" for around 1200 bucks and then spend around 450$ on a nitrous kit.. That will leave you a bit left over to get a tune.. Should put you VERY close to your 6.7 mark and will be within budget. I do not see you hitting 6.7s/10.6s with a 2000$ budget if you car is going to weigh over 3100lbs...
Yeah been thinking about the expense it going to cost also and dont want to or dont have the $$ for that. yeah oil pump, fast intake, injectors, other small stuff with probably add up to over $3000. And if i can limp the 10 bolt till it breaks all i have to do is buy the gas kit, retune it. And HSW has the plate kit on sale for $400. keep the ideas coming guys
The nitrous will give you more the heads and the cam put together. Tune just because you will need one.
Formerly darynC-10/23/10
if you know for sure that you want to do heads in the future . pick a cam that will match the heads that you are wanting to go with, that way when you come to that point, your setup will match and be optimal!
