Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Camaro and Firebird: LS Engine Camshaft Guide and General Information
Important information to help you understand your Camaro or Firebird
Z06 (LS6) cam vs. GM Hot Cam
My car was bult in apr 04 if that helps here's the vin 6G2VX12GX4L262153
I'd really like to know if my car has the ls6 cam
Ls2
Any help. Please. Building ls cast block ls3 heads automic Msd intake .
I am torn between what cam to use. Livernois stage2c l92 High lift,
Tick performance street heat stage 2ls3 l99
Tx speed tsunami v2.
Here's the truck info 69 suburban 513 gears 40" tires. 4l80e tranny
Who wants to give some advice
Thank you all for your time
It will work, but you lose a lot of low end power. I assume you mean the LATE cam which is 204/218 duration and about .550 lift. The early cam which is 204/211 and .525 lift would actually serve you better as it has much stronger low end power. This is the same grind as the LS2, but the LS2 does not have the cam sensor rings on the cam.
