Telling driver side from passenge side coil packs
After mounting my coil packs, I notice that, even though they are mounted to a bracket, it's possible to get them mixed up. The coil pack bolt pattern is flip flopped on each side, which can allows either bracket to mount to it. I tried to keep them seperate and am 99% sure I have them on their appropriate side, but I thought that the bolt pattern would be different.
Are there any markings, indicaters that the designate the appropriate side assuming that the coil packs are not the same? If they are wired exactly the same then I don't see a problem, but I haven't inspected this yet. Thanks
