Can LS1 heads be used on a 42x c.i. motor?
Can't you go with 6.0 liter heads and get the same performance on a large cube engine? I though the 6.0 liters had the same ports as LS6 heads, but they just have the monstro combustion chambers, which on a big cube motor should bring the compression to just about right.
Bigger cubes = mucho more compression. If I put these milled heads on the 427 I am building, rather than 10.8:1 compression like I have now on the 346, it would go up to something like 13.0:1!
The 6 liter heads do work VERY well. I would run them in a second. The LS1 heads would work just fine too. It's your pocket book so it's your choice. But my vote is for 6.0's speaking from personal experience.
Chris
Chris
