link for a speadsheet on valve sizes of LSX heads
Old 12-24-2009, 09:33 PM
badmfkr's Avatar
Default link for a speadsheet on valve sizes of LSX heads
I've sean it once before here now can't find the link for a speadsheet on valve sizes of all LSX heads.
Old 12-24-2009, 09:47 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That should cover your basics:
https://ls1tech.com/forums/1740922-post41.html
https://ls1tech.com/forums/generatio...-l92-info.html
All are stickies.
Try and you should be able to find anything you need.
Old 12-24-2009, 10:21 PM
02*C5's Avatar
This one will give you some flow numbers not all but enough to let you make a good educated decision;
http://www.theturboforums.com/smf/in...=122987.0;wap2
Old 01-01-2010, 07:27 AM
badmfkr's Avatar
All are stickies. I did read this stickie however I wanted to compare the 853s
Thanks for feedback
Thanks this is good infor.
I've sean a excel speadsheet on this site w/ all LSX heads, valve sizes, flow #s, chamber size, port size, compression ect.
the speadsheet makes comparing so much easier Thanks of feedback
