compression ratio help, please
Old 12-28-2009, 07:08 AM
Friday13th's Avatar
Default compression ratio help, please
I need help in calculating a compression ratio. I have searched and found formulas but I can't get it to work right. Please help if you could.
These are the details:
Stock 5.7 Block
Forged Flat Top pistons
4.8 heads (209cc intake/63cc chamber)
Valves 1.55/2.02
Old 12-28-2009, 07:25 AM
LS1MCSS's Avatar
What are your cam spec's?
Old 12-28-2009, 12:30 PM
Friday13th's Avatar
Stock 5.7 Block
Valves 1.55/2.02
Cam card reads:
Gross Valve Lift .608 / .608
Duration at .006 289 / 289
Lobe Lift .3580 / .3580
Lobe Separation 116
let me know if you need more info...
Old 12-28-2009, 02:36 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Are your pistons in or out of the hole? How much? What bore size are the pistons? What head gasket are you going to run?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-28-2009, 02:47 PM
...with cheese.
Armageddon's Avatar
I get 10.48 roughly. This is assuming you don't have valve reliefs in the piston... if you do it'll be closer to 10.
3.9 bore
.05 gasket
.01 deck
Old 12-28-2009, 05:39 PM
Friday13th's Avatar
Pistons are level with the top of the block. Pistons are factory bore and I do not believe they have valve reliefs. Not sure which head gaskets yet.
I am trying to get a rough estimate for CR ratio. I was told that my cam was great for a turbo and I figured I already had forged pistons and rods.
Assuming the CR Ratio is around 10.5 : 1, is this too high to run a turbo?
Old 12-29-2009, 07:38 AM
chrs1313's Avatar
Its not to high considering people run turbos/sc’s on stock vettes, which is right around the same 10.5:1, but is it ideal or going to give the best gains, probably not…
