Offset Grinding a stock Crank? Cost?
What's required for Offset Grinding a stock Crank?
New pistons and rods required for a .1 offset?
What's the typical cost for the machining to do an offset crank?
Longevity?
I wouldn't mind picking up a few extra cubes for the RS's new engine.
Thanks
Longevity?
Thanks
Longevity?
Thanks
Longevity?
Thanks
i just got this done to my motor here in town buy a good machine shop. it only cost me $150 for the labor. when i taked to the crank grinder, he explaned how it was a very simple process and he has done it hundeds of times for SBCs and many others. you can get the scat 2.00" rods for only $400 from a scat dealer. i have a pic of the set up under the nitrous section. the piston will have to be a custom job so that is the only expensive part. i only had it stroked to 3.71 from a 3.62 stock.
Everyone has been doing this for a while it is not a new thing. People have been doing this on motors since the 60`s. To go .100 under to 2.00" big end is where the stock old small block chevy`s were. They never had any longevity issues. We do this on the LS1 often it has worked so far.
Goodluck with the project, Nate
I think my cost was $300 on top of what I was already paying for the motor. Pistons & rods were not extra, I had to get forged ones anyway. I got mine from ARE, might want to give them a call.
I'd wait & see how the new Eagle cranks are gonna work out.
Originally Posted by Carvinta
How much stroke can you offset grind? Is it possible to get the 4" throw to plan for a 383 with offset grinding alone?
