LS6 cam/srings A4 shift points?
Old 12-17-2003, 08:43 PM
TNormZ28's Avatar
Default LS6 cam/srings A4 shift points?
What do you LS6 cam in an F-Body owners have your fuel cutoff set at and what are your shift points set at. I want to use my Predator to bump my shifts to 6200 and fuel cut off to 6500. My fuel cuts of a 6390 now and shifts at 6000, but sometimes the motor passes that shift point and hits the limiter.
Old 12-17-2003, 09:08 PM
DrkPhx's Avatar
I have the shift points at 6300 rpms and the rev limiter at 6500 rpms.
Old 12-17-2003, 10:43 PM
TNormZ28's Avatar
Does your car ever bounce off of the rev limiter? What other mods do you have and how much hp/tq and e/ts are you running? thanks,
