Has anyone seen this timing chain before
Has anyone ever seen or used this timing chain before?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448927824
yep.....its the Rollermaster (SLP, etc...) double roller chain. It works really well but if you are using an ASP pulley, you need to make sure the crank snout off the pulley does not hit the oil pump (BIG problem on vettes....not so big on F-bodies). Mine just tapped and rubbed for 25K miles with no "problem"....when I swapped oil pumps I turned the snout a tad to make sure it clears.
