How Fast Can You Spin A LS1
Old 01-04-2010, 08:05 PM
araber89's Avatar
Location: Holmes County (thats right Amish Country), OHIO
Default How Fast Can You Spin A LS1
So recently I have been getting cam fever again. I would like to do a swap to a big cam. Car is just a weekend warrior so cam size doesn't matter to much. However a lot of the cams I am looking at are saying max RPM is 6500 for the cam. I know I can up the RPM to 6500 without a problem but I am curious to how fast you guys run these motors on a stock bottom end? What will the stock bearings take before they take a dump? Also the car has 92XXX miles so I need to watch that a little.
Old 01-04-2010, 08:08 PM
02*C5's Avatar
My car has 85K and I red line at 7K and my shift points are at 6800.
Old 01-04-2010, 09:17 PM
SOMbitch's Avatar
99 has the same weak rodbolts as my 98 so I chose my cam to peak around 6500. That is as comfortable spinning w/o a rod bolt upgradade as I wanted to go...The problem is not the bearings but the rod bolts stretch and causes the the bearings to spin...
Old 01-04-2010, 09:19 PM
Minshall's Avatar
Ive got a 02 Z28 with 99k. I put Katech rod bolts in and i shift it at 7200. No problems here.
Old 01-04-2010, 09:29 PM
00blueLS1's Avatar
I got a 2000 Z28 no rod bolts with 93K rev limiter at 6400 shift point 6200 no problems yet
Old 01-04-2010, 10:22 PM
BriancWS6's Avatar
There are several threads with pages and pages of peoples testimony's on this subject.
Personally, I turned my stock bottom end car (02 model so it had the better rod bolts) pretty hard for close to 20k and never had an issue. Actual shifts occurred at about 6900. Prior to that rpm, I had the limiter set to 7100 trying different shift points at the track.
A buddy of mine turned his 00 bottom end car (weaker rod bolts) to 6800 for around 10k with no issue either.
Old 01-04-2010, 10:23 PM
therobman's Avatar
i have an 00 block and my limiters at 67 and i shift at 65
Old 01-04-2010, 10:33 PM
223HAWK's Avatar
Mines seen 7 several times..Y2k..but I know all good things come to an end also..
Old 01-05-2010, 03:03 AM
ae13291's Avatar
when did GM change the rod bolts on the LS1? i thought they changed them in 99?
Old 01-05-2010, 09:59 AM
396D1SS's Avatar
99 has the newer rod bolts 97-98 has the weak links
Old 01-05-2010, 11:21 AM
BriancWS6's Avatar
In-correct, the new rod bolts were introduced in 01. 97 (vette) 98, 99, and 00 all have the weaker ones.
Old 01-05-2010, 03:57 PM
Camaro99SS's Avatar
The 2000 and older motors redline at 6000 with a 6250 rev limiter. The 01+ redline at 6500 with a ~6700 rev limiter (Z06's). With a warranty covering this in a car designed to be driven hard, it's pretty safe to say the 01+ motors are good for 7000, maybe 7200 and the pre 01 motors can still handle 6500, 6800.
It's worth mentioning that alot of guys with stock 2 bolt head/cam LT1's wind theirs to 6500+ without causing problems. If those 2 bolt motors with heavier pistons and weaker rods (and probably bolts) can handle this, any LS1 certainly could.
Jason
Old 01-05-2010, 04:42 PM
ae13291's Avatar
Jason
the 01 LS6 is but the 01 LS1 is still the same redline. the LS6 also has a much lighter valvetrain
Old 01-05-2010, 08:54 PM
BriancWS6's Avatar
Jason
Actually, ALL LS1 cars, no matter the yr, have a 6200 fuel cutoff from the factory.
In 01 the rod bolts that came with the newly introduced LS6 were also used in the LS1 cars, but ONLY the Z06 got a bump in the rev limiter because it needed it with the better flowing heads and larger cam shaft. Also, the stock fuel cutoff for an LS6 is 6600.
Quick Reply: How Fast Can You Spin A LS1
