Motor Break In Question?
Old 01-05-2010, 04:16 PM
02BlkZ28's Avatar
Default Motor Break In Question?
I just built my motor heads and cam and went with bigger injectors and bigger fuel pump, and my question is on the break in process it says to normal drive the car for 4 to 6 hrs before getting on it....with bigger injectors do I have to worrie about washing out my rings from flooding it while breaking it in, Or should I get the car tuned even befor I drive it?
Old 01-05-2010, 04:19 PM
vaticano's Avatar
I would at the least get it tuned for the injectors.
Old 01-05-2010, 04:22 PM
02BlkZ28's Avatar
Im gonna get it tuned but I was wanting to know If I should get tuned befor I even break the motor in?
Old 01-05-2010, 04:26 PM
vaticano's Avatar
Yes.
Depending on how you want to break in the motor, maybe your tuner can set the IFR table for you then allow you to come back for the rest of the tune.
Or just let him tune it and not concern yourself with the break in.
Old 01-05-2010, 06:08 PM
01ssreda4's Avatar
You cannot crank this motor with the wrong size injectors in. They must be rescaled first before the intial crank up. Or put your stockers back in during break in.
Old 01-05-2010, 10:31 PM
02BlkZ28's Avatar
It wont lean the car out to much if I put the stock injectors in?
Old 01-05-2010, 11:12 PM
01ssreda4's Avatar
As long as you are driving around like a normal person you are fine on stock injectors. Dont go over 5K or anything crazy like that. You should use whatever injector you are tuned for period.
Old 01-05-2010, 11:17 PM
LS6427's Avatar
YES....you do have to worry about washing the rings. Get a tune.
It happened to a friend of mine on a brand new 427 stroker.
Rings set in a mile..or just a few hard dyno pulls. It does not take miles and miles and miles to break in the rings. And thats all you're breaking in, the rings.
Old 01-06-2010, 12:45 AM
blue by you's Avatar
If all you did was H/C, you don't have to "break in" the engine, but like the others said, you need to get it tuned for the bigger injectors.
Old 01-06-2010, 10:48 AM
02BlkZ28's Avatar
Thanks for the advice everyone...Ill talk to my tunner and see what he wants me to do.
Old 01-06-2010, 12:55 PM
bww3588's Avatar
20 minutes at 2000 rpm and the rings are broke in. thats 2000 rpm not under a load. start it up and get it to 2000 rpm and leave it there for 20 minutes.
