push rod length
Old 01-06-2010, 04:43 PM
Turd Gen Guy
1nasty86's Avatar
Default push rod length
looking at my pushrod checker it seems to like the 7.300 length. does this seem right for a 5.3 with 243 heads shaved .030 with a .040 head gasket???
Old 01-06-2010, 04:46 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
How did you measure?? Are you using Comp's 7702-1 pushrod length tool? How many turns did it take to get from your zero lash length back to the fully screwed-in length? 7.300" isn't out of the realm of possibility, but it's not terribly common either.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-06-2010, 04:54 PM
Turd Gen Guy
1nasty86's Avatar
yes im using comp. length checker. the 7.400 is way too long. turning it a full turn down gives me 7.350 correct? as the rocker arm is torqued it compresses the spring a little bit. so i tried another 1/4 turn which gives the 7.325. still tries to compress the spring. another 1/4 turn gives should give 7.300. it just does touch the rocker arm. does this sound correct?
Old 01-06-2010, 05:13 PM
So you're using a known 7.400" pushrod and using the .012" per 1/4 turn on the rocker trick? Or are you putting the lifter on the base circle and running the checker tool out to zero lash with the rocker arm torqued to 22ftlbs, and then counting how many turns on the tool it takes to get back to the short length of 6.800"??
__________________
Old 01-06-2010, 05:15 PM
Turd Gen Guy
1nasty86's Avatar
im turning the checker to the specified length then torqueing the rocker arm down.
Old 01-06-2010, 07:47 PM
vettenuts's Avatar
Based on what I think you are describing, the 7.300 is a little loose and the 7.325 is more then snug, you need to add in the preload of the lifter so the final number is going to end up around 7.375"-7.400".
Old 01-06-2010, 10:02 PM
Turd Gen Guy
1nasty86's Avatar
i was told by john at texas speed that he thought id need the 3.750 pushrods... becuase the 7.400 are WAY too long
Old 01-07-2010, 06:31 PM
Turd Gen Guy
1nasty86's Avatar
twisting the length checker to 0 lash is 9 1/2 turns... that equals 7.275....
Old 01-08-2010, 08:55 AM
Turd Gen Guy
1nasty86's Avatar
bump for some info.
Old 01-08-2010, 09:36 AM
7.350" will set you up with right at .075" preload. That should work fine for the GM lifters, if that's what you're running.
__________________
