Which LSA???
Which LSA???
Hey guy's just been reading through some threads and noticed and a very popular cam for a stock head LS1 is 224/224 with either 112 or 114 LSA's. I'm looking at getting the same for mine but on 110 LSA.What difference will it make. I thought the reason you guy's use the 112 or 114 might be because of emmision's? Not a problem here in Aus thankfully.
Cheers!
Cheers!
No difference in power hugh. How many cars with 224 cams make 406 peak rwtq on stock heads and 380+ rwtq onstock heads from 3000 rpm up. Put that cam on a 110lsa, you will not be sorry. Being able to tune with ls1 edit does help with cams with more overlap (lower lsa) so be for warned.
my dyno:
http://members.aol.com/blueflame6469/images/dyno2.jpg
my dyno:
Thanks for the reply's.
Bringing the peak power down lower in the rev range sound's good and getting a good tune won't be a problem.
Any other comment's?
Idle nightmares.Depending on your car use ie: What is the powerband needed for your application? That is one of the perimeters that determine lsa choice.
