best budget heads for 6.0 besides the l92's???
Old 01-11-2010, 01:27 PM
3pedals's Avatar
Default best budget heads for 6.0 besides the l92's???
I'm an LS newbie, i've read here for quite a while, but I'm still learning. For a total BUDGET build, what are the best stock heads(with possible porting) to use for a 6.0, with little more than a cam and spring change? I am very capable of porting my own heads, as I have done many BBC and sbc heads, but I've never worked with an LS motor before. Are the stock 6.0 heads good w/ porting, or would a smaller cc chamber head flow as well after porting AND give me some compression? I could not find stock valve sizes for the different heads here?
I am trying to determine if I should sell my 454 and go LS......I am realy liking the LS from what I read. Street/strip 67 camaro w/ previous best of 12.00 @ 115 w/mild 454 4 speed.
ps I will run the vic jr intake/msd box and a carb.
Old 01-11-2010, 02:20 PM
02*C5's Avatar
243s hand down, LS6 valves and Yella Terra Rockers for a really stout build. You can also do the stock LS rockers but I would not advise it if your going higher than a 650 lift cam.
Old 01-11-2010, 02:29 PM
Jon@Texas-Speed's Avatar
I would look at a set of LS6 heads. They will be the better head to be begin with if you are going to try and port it yourself. They are similar to the 6.0L heads but with a smaller (64cc) combustion chamber.
If you decide you want someone else to port them let us know, we can CNC port and CNC valvejob them for you for $650!
Jon
Old 01-11-2010, 03:07 PM
02*C5's Avatar
Jon
^^^ great price.
Old 01-11-2010, 07:18 PM
NemeSS's Avatar
Jon
what he said.
even in stock form the 243/799 heads are very potent when correctly matched with supporting parts.
Old 01-11-2010, 09:38 PM
jrob56's Avatar
why do you want to go with something other than l92's? seems like that would def be the way to go in my book. would the 243's really be better?
Old 01-11-2010, 10:42 PM
3pedals's Avatar
I'm still learning about ls motors, and apearently lots of others are still learning how to cam the large runner L92 heads effectively for smaller cube motors like a stock 6.0. I may go with the l92 heads in the end, but want opinions of those who have made power with the other factory available heads, and done it on the cheap.
thanks for the thoughts so far, keep em commin. which route will be more $$$ effective - ported LS6/243 heads, or L92's? andhave guys figured out how to cam the L92's yet?
Old 01-11-2010, 10:47 PM
jrob56's Avatar
id talk to pred z or pat g and see if they would be able to spec one out for you.
Old 01-12-2010, 02:08 PM
02*C5's Avatar
Ed Curtis should fall in that camp
Old 01-12-2010, 04:46 PM
TT632's Avatar
This thread has some good basic input on the L92 head topic. https://ls1tech.com/forums/generatio...whos-best.html Patrick has some right on statements regarding the l92 heads; simple and to the point. Theres is nothing that special about these heads or any LS head when it comes to picking a cam. Flow and Fluid/Gas dynamics do not change because they have an LS attached their name. People on many LS sites would have you believe that these heads somehow defy the laws of physic, they don't.
Quick Reply: best budget heads for 6.0 besides the l92's???
