?s about 03 6.0 lq4 with L92 heads
need some help with this im getting block cleaned up and i need to know if i can get some part #s for the following
03 6.0 main, rod, and cam bearings
shouldi use L92 head gaskets or 03 mls gm 6.0
another thing is when i layed the heads on the block theres a half an inch space from the head not covering the whole block on each side except one is in the front and the other on the rear of block ... is this normal? i never seen it before...
