do i have everything for my cam install?
hey, im going to be putting my cam in within the next 3 weeks. i just wanna make sure i got everything i need before i start tearing it apart.
heres a list of everthing i got:
Ms4 cam
patriot gold dual springs, retianers, locks, seats
comp 7.4 pushrods
valve stem seals(16)
HD timing chain set
thunder racing camshaft install gasket set
is that all im gonna need for my cam swap?
Ms4 cam
comp 7.4 pushrods
HD timing chain set
yea man you should add head gaskets, head bolts, lifters and WITH OUT A DOUBT A OIL PUMP...i put my cam in with stock pump and stock lifters and my oil only gets to 60psi at W.O.T. and my lifters sometimes tick....
LS1Tech Premium Sponsor
Check that pushrod length....more often than not with that aggressive intake lobe you'll end up needing a 7.425" pushrod to get the preload where it needs to be!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
New crank pulley bolt
pipe for breaker bar to loosen crank pulley bolt
small 3 arm pulley puller from Autozone
Valve spring compressor
Thread locker (blue - medium strength)
Assembly lube (put a little bit on the retainers so that they will stick to the valve stem while you are installing your springs)
printed instruction from www.ls1howto.com including the tools they recommend
