MOTOR IS TICKING Ls6 HEAD STOCK BOTTOM
Old 01-14-2010, 12:29 AM
99bluehawk's Avatar
Default MOTOR IS TICKING Ls6 HEAD STOCK BOTTOM
Ok i recently rebuilt my motor. Everything is stock and new except for the cam and valvetrain. The motor runs fine and it has oil pressure is at 60 during idle. I hear a ticking noise up on top coming out of the valvetrain. I was wondering since I went from 853 heads to 243 heads if that will affect the length of my pushrods? I thought LS6 motors and LS1 motors had the same length pushrods. I took off the valve covers and everything looks good. What is my next step? I already re-torqued the rocker arms to spec.
-Bert
Old 01-14-2010, 07:00 AM
after dark's Avatar
-Bert
Nope...if I'm not mistaken, the valves on the LS6 are shorter or longer (not sure which) compared to the LS1. I would get a pushrod length checker and verify it.
Old 01-14-2010, 10:58 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Agreed, check your pushrod/preload to ensure that is not the source of your noise.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-14-2010, 01:57 PM
Bowtie Guy's Avatar
LS6 valves are longer to account for the LS6 cams smaller base circle. Check PR length,lifter preload,etc.
Old 01-14-2010, 02:04 PM
5.3LJimmy's Avatar
What cam shaft are you running? Some valvetrain noise is normal depending on the ramp rate of the cam lobes. A quick search for "sewing machine sound" should yield some videos for you to compare against the sound you are hearing.
Old 01-14-2010, 02:31 PM
99bluehawk's Avatar
I have a stock 99 cam thats why I thought it would be ok to use stock pushrods and valvetrain.
Old 01-14-2010, 02:56 PM
5.3LJimmy's Avatar
Gotcha. The way it was worded made it sound like you had an aftermarket cam. If your heads did come off an actual LS6 the the valves will be longer(as stated above), and you will need to adjust the pushrod length to preload the lifters correctly.
Old 01-14-2010, 03:11 PM
99bluehawk's Avatar
Sorry to confuse you. I adjust the pushrod preload just by changing the pushrods to the correct length?
-Bert
Old 01-14-2010, 03:31 PM
Monte4ever's Avatar
Yes. ^^^
Old 01-14-2010, 05:24 PM
99bluehawk's Avatar
What lenght pushrods come in the LS6 motors?
Old 01-14-2010, 05:35 PM
salemetro's Avatar
They are both (ls1/ls6) 7.400
That being said, still check with a pushrod length checker.
Old 01-17-2010, 10:08 PM
99bluehawk's Avatar
Ok, I took the valvecovers off and on the driver side valve cover one of the rocker arms was hittin under the valve cover. Has any one seen this before?
-Bert
Old 01-19-2010, 12:11 AM
99bluehawk's Avatar
Well got it running again and I dont think it was the rocker hitting the valve cover because it still ticks.
