Oil Pan Question?
Old 12-20-2003, 12:26 PM
Solid346's Avatar
Question Oil Pan Question?
can i changed the factory Oil Pan to the Canton Pan while the engine in the car?
thanks
Old 12-20-2003, 12:31 PM
2001CamaroGuy's Avatar
? is that a dry sump pan?
what solid lifters did you use in your 348?
Old 12-20-2003, 12:40 PM
Solid346's Avatar
the pan will be wet? any knowladge if it can be done while te engine in the car?
the lifters are Schubeck and it was recommanded by Allan Futral
Old 12-20-2003, 12:45 PM
It can be done but it's really hard. You pull the motor mounts and jack the motor up (place jack on the bellhousing of the tranny) as high as it will go and then you can usually wiggle the pan off.
Do you have any pics/links to this oil pan? Whats the gain of going to this pan?
Also, do you have a link to the lifters? I suppose they are a direct replacement for the LS1s hydrolic lifters. What did they cost a set?
