Need Help!
Old 01-27-2008, 05:12 PM
COOKIE MONSTER's Avatar
Default Need Help!
Guys,
My trans am is throwning me some issues after going to the drag strip tonight.
For about a week now, I've been having strange readings on my fuel guage. 1 minute everything is normal, the next minute I'm on E, and back and forth.
On the way home, I noticed my temp guage was getting close to red. I went to a friend's house, and turn off the car, and my fan is still running!??? WTF
After the fan turns off, we could here the coolant boiling in the raidiator... I turn her back on after about 20mins, and she ran fine. I took here down the road to open her up, and I do. She ran great. Next thing I know, my Temp guage is back up while I'm sitting at an intersection and WHITE smoke pouring out the back. I mean white smoke everywhere! People where laughing at me lol. I took off slowly from the light, and as I started goin' and goin' the smoke stopped again. I pulled over again, smoke everywhere as soon as I stopped, and the Temp was off the guage.
What the hell is wrong with my car?
Seal from driving it too hard? Coolant? Fuel?
All of the above?
Please help me...
Old 01-27-2008, 05:37 PM
Bump>>>>>>>>>>>>>>>>
Old 01-27-2008, 05:40 PM
Bump>>>>>>>>>>>>>>>>>>>>>>>>>>>
Old 01-27-2008, 05:43 PM
405HP_Z06's Avatar
From the limited information, it sounds like you have a head gasket issue.
Old 01-27-2008, 05:57 PM
99mongooSS's Avatar
X2, I cant think of any thing else. Have you checked the basic parts in the cooling system? How did they look? If they all check out fine from what you can tell, then check head gaskets.
Old 01-27-2008, 06:16 PM
I DON'T have smoke coming from the heads though. Or anywhere under the hood...
Old 01-27-2008, 06:50 PM
BigBirdTA's Avatar
You blew a headgasket. White smoke = coolant steam, blue smoke = burning oil, black smoke = unburned fuel (pig rich).
Old 01-27-2008, 08:22 PM
How are you so sure? I just got new head gaskets, heads, everything is still new above the crank....
Old 01-27-2008, 08:42 PM
405HP_Z06's Avatar
It doesn't matter how new the parts are. Many things can affect head gasket seal and it's not uncommon to have these issues. Keep driving it like it is and you'll be replacing everything around the crank.
Old 01-27-2008, 08:59 PM
5.3LJimmy's Avatar
You definitely blew a head gasket. The fans will stay on w/ the ignition off if the car is over a certain temperature, so that's normal. The fuel gauge is an unrelated issue and sounds like a bad sending unit. What kind of head gaskets are you running?
Old 01-27-2008, 09:14 PM
I got GM Gaskets.
Old 01-27-2008, 09:15 PM
What about a water pump? Thermostat stick? Coolant?
Why could it not be one of those problems?
Old 01-27-2008, 09:26 PM
caMnaro's Avatar
all of those are contained in the cooling system.If one was broke or malfunctioning it would not make it to the exhaust system. If something went wrong in the cooling system and then overheated then your head gaskets went.
Apollo0526's Avatar
Is there water in the oil?
Old 01-27-2008, 09:28 PM
Don't know yet.
Old 01-27-2008, 11:38 PM
SSMOKIN_Y2KSS's Avatar
sounds like u blew a head gasket for sure...maybe u have a bad fuel float...and a bad coolant temp sensor..but the smoke =head gasket..check ur oil...any water...or white looking milkyness
Old 01-27-2008, 11:48 PM
Should I just drain all the oil out or Just use the dip stick?
Old 01-27-2008, 11:50 PM
blksheep's Avatar
you can tell from it on the dip stick... it will look sorta like chocolate milk...and it def. sounds like a head gasket...
Old 01-27-2008, 11:53 PM
yah dip stick should tell u...but if that doesnt tell u then for sure drain the oil and look for any unordinary metal...if theres metal...pull the pan off and start searching for mis. parts. no parts check those bearings
