which head is best?
Old 01-20-2010, 04:06 PM
bww3588's Avatar
Default which head is best?
i have 2 sets of heads laying in the garage, im going to send one set out to TEA to be CNC'd. one is a set of 241's and the other is a set of 853's, if you were in my sitiuation, which would you send out.
they are going on my H/C/I 346 MS4 11.3:1 FAST 90/90 motor.
Old 01-20-2010, 04:13 PM
02*C5's Avatar
They are the same head just different casting styles between the two no one head is better than the other.
Old 01-20-2010, 04:25 PM
bww3588's Avatar
i didnt think so, i was out just a minute ago looking at them and couldnt see any difference. both were off 99 camaros...
Old 01-20-2010, 04:36 PM
02*C5's Avatar
If you can swing it for a stock head do 243s just IMHO and its just that my opinion. I have had both and I preference 243s.
Old 01-20-2010, 11:19 PM
bww3588's Avatar
Originally Posted by 96TransAmM6
the best head comes from fat girls
touche' salesman...
Old 01-20-2010, 11:20 PM
bww3588's Avatar
i would like to do a set of LS6 heads, 799's or 243's but i already have these heads, and this is just a for now motor till i can afford the 408.
Old 01-20-2010, 11:24 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Only thing I would suggest is the 241 over the 853. Perimeter bolt valve covers look hideous. If you have vc's and coil brackets for either than it doesnt really matter. They will make the same power in the end. If you were to re sell them in the future though the 241 would look more appealing to someone that would want nothing to do with the 853 because they just know its the older model.
Old 01-20-2010, 11:28 PM
bww3588's Avatar
you are thinking of the 806 heads that had perimiter bolt valvecovers. the 853's were center bolts as well. they both came off 99 z28's
Old 01-20-2010, 11:30 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ha! Yes, you're right! Then again. No difference with the 853/241's. Porting would change any small thing that may have been altered btwn the 2 anyway. It could be a simple water jacket route that was different that wouldnt affect flow. I'm not really sure.
Old 01-20-2010, 11:34 PM
bww3588's Avatar
thats a good point, i guess the ports are where they are and i didnt think for some reason that a cnc port job is going to make the ports the same no matter what head. good call sir.
Old 01-20-2010, 11:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
yeah, cause its gonna be the same program that will run for either head. At that point you could grind off the casting number and make your own. lol.
I dont know what the heck I was thinking with the 853's. You clearly said 99 camaro. That should have been a dead giveaway. 2 years off from having an LS motor and I am slipping!!!
Old 01-20-2010, 11:42 PM
bww3588's Avatar
dont feel bad, i havent driven my car in over a year, im losing my instant recall on things i should know about them as well. i think the less i drive my car, the less things to go wrong that i have to think about and refresh my memory.
Old 01-20-2010, 11:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
truestory
Old 01-20-2010, 11:49 PM
bww3588's Avatar
hey thanks for pickin my brain guys. ls1tech is the ****.
Old 01-24-2010, 10:06 PM
bww3588's Avatar
ok, i was looking at the heads again. is there any difference in the valves between the two? or should there be anyways? i noticed in the 853 heads, the exhaust valve has a pretty good dish to it, where as on the 241 heads, it is flat. i know this will give me a little more compression, but should there be a difference in valves or did someone change them to something else? what would they be?
here are some pics i snapped.
Old 01-25-2010, 04:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Wish I could see the pics at work.
I know what you are talking about though. Never thought about it like that.
Old 01-25-2010, 08:31 AM
ringram's Avatar
853 are sandcast and 241 lost wax IIRC.
So in theory the 853 might be a little more rough in the ports. But if you are CNC them, then it doesnt matter.
Old 01-25-2010, 09:49 AM
oange ss's Avatar
SPM cast, not wax...better consistency due to less core shift and "smoother" finish...if there are large triangles below the exhaust ports then they are SPM cast heads
