victor jr 346?
Old 01-21-2010, 11:55 PM
1sicws6's Avatar
Default victor jr 346?
im getting ready to install a victor jr and accufab throttle body on my car just wondering if my cam will work with these type of runners.. the cam in it is a t-rex and the doctor sheet shows it a 244/250 on a 109 lsa.
Old 01-22-2010, 12:32 AM
StreetSilverado's Avatar
244/250? Good god thats a huge cam for that little 346. My little 370 only has a 238/246
Are you sure it's a Trex cam? I thought they were a 23x/24x? I'd look for something like a 23x/23x .60x/.61x on about a 109 or 110lsa.
Old 01-22-2010, 01:30 AM
1sicws6's Avatar
yeah thats advertised spec the cam has a doctor sheet
Old 01-22-2010, 11:26 AM
mark21742's Avatar
Should work fine, might even let it idle better
Old 01-22-2010, 11:27 AM
Banned Village Idiot LS1BLKSS
BLK:UFO's Avatar
that is a huge cam, what kind of numbers/ times you got with that?
Old 01-22-2010, 08:44 PM
1sicws6's Avatar
443/405 torque cam only with a fast intake only been to the track once on stock suspension 11.6 @124
Old 01-23-2010, 10:34 AM
mark21742's Avatar
I can not wait till the track opens back up so I can run my new setup with slicks and get a good time
Old 01-23-2010, 10:40 AM
tillery's Avatar
For an all out track car, the single plane intake will work alot better over the F.A.S.T. Its runners are short and large open plenum works in the power band of that cams advertised duration. Meaning better matched.
Old 01-24-2010, 12:57 AM
1sicws6's Avatar
That was my guess and honestly its my daily driver but all I care about is track performance, and im also changing the gears to a 4:56
Old 01-24-2010, 10:13 AM
tillery's Avatar
It can be still driven on the street. just the low end will feel non existant. 4:56s huh? running a 28" tall tire or 1/8 mile? Thats alot cam/gears and intake for a D/D.
Old 01-25-2010, 01:14 PM
1sicws6's Avatar
I have 4:30's right now with a 27 mt dr my 4th gear is about 135 and yeah I plan on running a 28 tall tire if I do need it with the 4:56, im use to a 5 speed mustang with a tiny tire and 4:10, way worse then my setup now so i'll be fine
Old 01-25-2010, 09:21 PM
burlst/a's Avatar
i got that intake on my stock engine.i lost no low end what so ever.pulls from 1000 rpm in 6 th at 40 mph and has no problem doing it with 3.73 in my swapped mustang.
