5.3 Motor in F-Body. Need ADVICE!!!
Posting for a friend....
I have a 5.3L motor going into a 99 Camaro SS. Its completely stock, the internal mods are Ls6 CamShaft and Ls2 Springs. Everything is interchangable from a 5.7 to a 5.3, but the question was about the "crank reluctor wheel" (i think is what its called) is different and has a different pattern from the 5.7 and different size. Im worried it will not turn on at all because of the signal its sending through the crank sensor, but the source of the problem is the "crank reluctor wheel". If anybody has put a 5.3 motor (NOT JUST HEADS) to let me know if they changed this and the crankshaft. Its said that the crank is almost identical though. I dont want to install and for it not to turn on. I know it might run shitty until I get it tuned but I just want it to turn on. ANY advice will be appreciated. If somebody can pm me a response or to this cell # (214)-803-0154. or you can reply on here. Preferable the first two but any help is good. Thanks guys!!!
i did a 5.3l in an f-body, havn't started it. When i flash the ecm im going to put in the 5.3l tune. Unless its a new 58x wheel (grey sensor) it will work w the stock 24x (black sensor) ecm.
well thats because i had crazy ported 5.3s and a huge trex cam in my original motor that was not setup correctly and the cam got wiped and thats why i dont let anyone else do work on my car anymore. sold the heads to buy the shortblock and said i dont have to go so crazy this time. sorry if i came off like a douch or something...bad day
The reason for 5.3 in an F-body is because they are cheap. I'm doing the same thing. since I destroyed my 5.7. I am putting a 218/218 . 563 .563 114 lsa and comp 918s according to Mike the guy installing the engine its won't be any different tha the stock 5.7. OP let us know how this turns out.
If the 5.3 is a 99-06.5 you dont need a conversion box, because it has the same reluctor wheel as an ls1. Swap in the motor and it should start up. The 5.3 actually runs quite well in a light car compared to a hefty truck and its usually alot cheaper than the ls1.
