Different years, Different 24x reluctor wheels?
I'm building a LS1 out of a '99 Firebird. The crank snout was slightly bent so I bought a used crank out of a '02 Camaro. Even though the reluctor wheels are both 24x, they look very different. On the '99 the plates are tight together and the notches are a lot thicker and spaced differently. Is this going to work with the '99 computer?
'02 on the left '99 on the right
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Looking at the two and comparing the tooth pattern, they should give equivalent signals to the computer. I've only seen the one on the left but I do know I have interchanged 24X cranks from nearly all different years with no issues.
Shane
Shane
Thanks Shane. I found this old thread, looks like same issue I have. I don't know if this guy his to work or not. I hate to put this all together and find out it won't work
https://ls1tech.com/forums/generatio...light=reluctor
