goin bigger spec me a cam plz
Old 01-23-2010, 04:42 PM
bulldogSS's Avatar
Default goin bigger spec me a cam plz
im thinking of going bigger on my cam and i need some help picking a cam. here are the mods on my truck. Katech stage II 241s, .40 gaskets(around 10.75/1 comp.), 44#er, lts, dual exhaust, ported tb, circle D 3000, flt lvl4. the truck is a silvy SS awd DD and sees some limited track time. any help would be appreciated. thanks Mark
Old 01-23-2010, 08:29 PM
johnster's Avatar
big cams need big stall 3000 ant that big if you wont to run a cam in the hi 230s or low 240s get a bigger stall
Old 01-23-2010, 10:30 PM
02*C5's Avatar
Contact Pat G, Ed Curtis, or Pred Z those are the top 3 guys you want to talk to about specking u out a cam. Then have the heads done by TEA or AI to cam specs and you will not be sorry.
I am running a 3400 stall and my cam is 23X/24X w/ no surge or anything. The tune has a lot to do with how your cal will run. I would not go below 3400 though with a cam in the numbers mentioned above.
