looking for your opinions
Old 01-24-2010, 10:24 PM
Robs99TA's Avatar
Default looking for your opinions
I I would like to know what kind of numbers people think I might be putting down with my setup. The easiest way would be to Dyno it but the problem is there is not one in my area (Alaska).
I have the following
LS6 Intake
SLP Lid
30lb red top injectors
228R Cam 7.400 pushrods LS7 lifters
LS6 oil pump
Pace setter long tubes
Magna flow cat back
241 heads 3 angle valve job and milled .020 Bump Compression (does anyone know how much it bumped my compression up)
I am going to have it tuned by Texas speed (mail order)
With a 3200 Circle D converter
What else might I need to reach 400RWHP I have an A4 in a 99 TA with 373 gears?
Old 01-24-2010, 11:36 PM
Quik Sand's Avatar
LS6 Intake
SLP Lid
LS6 oil pump
Magna flow cat back
As it sits before tune, I would guess 385-395 whp. Im not sure how much those heads milled will give you. With tune, pulley, and cutout I would say you can meet your goals. Im sure others with more experiece with stalled cars on the dyno will answer better.
Old 01-25-2010, 03:24 PM
Brandon35thSS's Avatar
your setup is very similar to mine. my numbers are in my sig.
Old 01-27-2010, 07:36 PM
Mark1si's Avatar
Get bigger injectors!!!! Get the 42's.
Old 01-27-2010, 07:39 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I expect with mostly stock heads you'll be making right at 375rwhp with the verter locked. We'll make sure & get that tune lined out for ya, let me know if there's anything else we can get you!
Thanks
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-20-2010, 03:23 PM
cool87gn's Avatar
Rob, what unit are you in? I am in PFAR and we are returning from Afghanistan next week.
Old 02-21-2010, 10:37 AM
jonlisa973's Avatar
390 at the wheels
