connector identification
I am new to the ls1/ls6 scene. I just picked up a ls6 out of an 03 zo6 and going to be swapping it in my 68 nova, I am about to order coil packs and brackets for the engine but what are these two connectors.
It looks like they are on the coil pack bracket but what are they?
I am doing a carb swap and have scene them been used even with a carb, I just need help in what these sensors are. They are mounted in the middle of the coil packs on both sides. it is right after the second coil pack and right before the third
http://www.zorly.com/images_camaro/g...0%28LS1%29.jpg
They are the connectors for the coil packs they connect the coils to the engine harness. You can use a carb but you will need the msd controller to drive the coils if you dont have an engine harness and a pcm.
