What rockers for my application?
I've been reading up on some rocker choices, but I'm having a hard time coming to a decision.
Right now I'm running the stockers at .646" lift which I hear is close to the limit for a stock rocker. I'm also running ETP 245 heads and I would like to avoid grinding on them to make clearance if possible.
I've been leaning towards Harland Sharp non-adjustables, but I will go to something like Jesel if they're worth twice the cost of HS. What do you guys think?
Jesel you can't go wrong with the other choice would be Yella Terra. If you want to keep the stock rockers(the lightest available) and want to ease your worry get the trunion upgrade, the needle bearings is the one thing that hold the stokers back. IMHO
DO NOT DO HS don't trust them and have seen a lot of VT failure, now that's on stoker heads but again just my .02.
