I need a blower cam that will pass emission tests. Help?
Hi,
I'm going install a Procharger P-1SC-1 6 psi kit + alycontrol before summer and why not stick in a blower cam since the engine comes out for lifter swap. Problem is that in Finland where I live there is an annual sniffer test. Limits are quite strict, for example HC must be below 100 ppm at idle (max 1000 rpm) and CO limit is 0,5%.
Now I have Comp Cams 216/220 525/.532 114 LSA -cam and it passes sniffer like nothing and it's not even tuned yet. So what kind of a blower cam should I be looking for?
Thanks
J-P
Thanks
J-P
Thanks for the responses guys! My goal for the next summer is to make at least 500 rwhp with almost stock bottom end (Almost = ARP bolts, after market piston rings and new bearings for everything). If the cam that I have now is capable of that kind of HP I will be keeping it. After all, it's a great cam for a low end torque.
