Difference btw GTO and Vette LS1
Old 01-27-2010, 11:33 PM
mjollnir's Avatar
Post Difference btw GTO and Vette LS1
How do you explain the power/torque diff from these same engines?
Different camshafts or intakes?
rgds,
Ben
04 gto:
350 hp
495 Nm (pas bon)
2004 Pontiac GTO Performance
- 5,665 cc 5.7 liters V 8 front engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, overhead valve and two valves per cylinder LS1
- Premium unleaded fuel 91
- Fuel economy EPA highway (mpg): 21 and EPA city (mpg): 16
- Multi-point injection fuel system
18.5 gallon main premium unleaded fuel tank
- Power: 261 kW , 350 HP SAE @ 5,200 rpm; 365 ft lb , 495 Nm @ 4,000 rpm
00 vette:
345 hp
475 Nm
2000 Chevrolet Corvette Performance
- 5,665 cc 5.7 liters 8 V front engine with 99 mm bore, 92 mm stroke, 10.1 compression ratio, overhead valve and two valves per cylinder
- Fuel economy EPA highway (l/100km): 8.4
- Main 72 liter premium unleaded fuel tank
- Power: SAE and 257 kW , 345 HP @ 5,600 rpm; 350 ft lb , 475 Nm @ 4,400 rpm
Old 01-28-2010, 01:41 AM
Sid447's Avatar
Smile
Camshafts,
are all but identical.
Vette GM tuned, GTO Holden tuned.
Side by side the tunes are quite different.
Though installation differences too (intake and exhaust).
Old 01-28-2010, 02:27 AM
ZTwentyAteU's Avatar
GM ratings
Old 01-28-2010, 12:46 PM
LS1W66's Avatar
Well for one thing your comparing an early LS1 (pre `01) to the last LS1.
It's pretty common knowlede that all LS1's from `01 -04 are identical save for differences of oilpans and intake /exhaust tracks. The `00 Vette engine has a different cam and an LS1 intake, where as the `04 has the LS6 intake.
Old 01-28-2010, 03:01 PM
chopperloco's Avatar
...and about 500 lbs.!
I've got both...
Old 01-29-2010, 12:44 AM
Sid447's Avatar
Smile
I've got both...
Yer not wrong! ~1470 and ~1695kg.
Plus the gearing difference.
