Help !!!! hot after head install
ok so here is the deal i did a head and cam swap about a week ago and after start up i have notice that it doesn't really overheat it just gets hotter alot quicker is that normal? i didn't want to hurt anything
yeah the heads gaskets are on right, and how do you get all the air out or make sure i did, its just some ported and polished 241's with a comp custon grind nitrous cam, w/the fast 92mm intake throttle body combo, the car doesnt over heat at all, i thought the sensor might be reading air but i can also turn the heater on at its alreay hot also
To get most of the air out let the car cool down and just disconnect the highest hose u can get to,
fill the coolant up at the radiator cap when u start to see coolant where u separated the system or it wont take any more coolant seal it up,
let it run till it warms up let it cool and top off the radiator and overflow tank usually that takes care of it
