How much rwhp should I have with 233/239 112, tsp 5.3 heads, fast 92, cutout
Sup guys I'm wondering how much power I should have. Currently have 408 to the wheels. Hearing I should get a tsp tune
Setup-
TSP 233/239 112lsa
FAST 92mm
5.3 CNC Ported TSP Heads
QTP Electric Cut-Out
Setup-
TSP 233/239 112lsa
FAST 92mm
I have those heads with a 232/238 cam,and hedman 1 5/8 stepped to 1 3/4 lt headers ...I'm in A4 though so my numbers will be lower
here it goes..When I had the above set up with a TCI 3500stall and 3:23 gears it put down 435rwp 407rwt..
put in 3:73 gears and lost some on the dyno.cant remember but it was around 8 I think..
Then threw in a bigger stall which robs "dyno numbers" and it was a 5c 4400 stall,but I also switched my old headers out form the Hedman 1 5/8 stepped to 1 3/4 lt headers to hooker 1 7/8..Anywa longstory short I put down 426rwhp now
Hope this helps
Hope this helps
I got the same heads but running a torquer V2 cam with aluminum ls6 intake, pacesetter LT and tsp rumbler exhaust with 4.10 gears. I made 443rwhp, 411 rwtq. So with your bigger cam I would say at least 450-460 depending on tune.
