What Type of Head Gaskets
Old 01-31-2010, 01:09 AM
99SS#20's Avatar
Default What Type of Head Gaskets
I have done some searching and found people split on Cometic gaskets. When I checked Felpro and TFS both make a MLS gasket like the Cometic. Are these gaskets as particular about finish as the Cometic MLS? I was hoping for a thinner than stock gasket for a compression bump, but I'm only changing heads, so I'm worried about the block surface.
Old 01-31-2010, 07:22 AM
69LT1Bird's Avatar
For the price difference between Cometics and stock GM gaskets, it maybe cheaper to have the heads milled to achieve the same thing. Around here is costs about $75 for the pair to have them milled.
Old 01-31-2010, 07:48 PM
99SS#20's Avatar
Very good idea, thanks for the info!
Old 02-01-2010, 07:14 PM
357i's Avatar
Thats what I did, $90 to cut the heads and I just bought a GM head gasket/bolt kit from LPE
Old 02-02-2010, 08:08 AM
helicoil's Avatar
The Felpro 1041 is a composite gasket that works fine for NA, with even a little power adder, (up to 150 shot) measuring .041" thick compressed. It is not as finicky as a MLS gasket either for surface finish. The price ain't too bad either.
Old 02-02-2010, 10:06 AM
transam69230's Avatar
If you use a composite gasket, and you change your heads be prepared for some major cleaning of the deck surface. MLS are a much better choice IMO as they require less clean up if you have to remove them.
Old 02-03-2010, 03:50 AM
99SS#20's Avatar
I was planning on running a 150-200 shot. I don't mind doing prep work, just don't want to pull the motor to have to mill the surfaces.
Old 02-03-2010, 04:37 AM
LSxPwrDZ's Avatar
I'm going with LS3 gaskets on my 403.. they are .051" 5-layer MLS... they are supposed to hold up better than the LS2 3-layer gaskets do (not saying the LS2 gaskets are weak cause they arent!!)
Old 02-03-2010, 08:16 AM
helicoil's Avatar
Only if they are 'graphite', not composite. Two totally different non-MLS gaskets. Graphite was OE on older LS1's, GM never used composite head gaskets on these engines.
Old 02-03-2010, 10:01 AM
Learn something new everyday!
