need help on cams please
Old 01-31-2010, 10:55 PM
michaelnrandi's Avatar
Default need help on cams please
i have a 01 ta ws6 has long tubes and 3 in Y with a bullit just got the car but i want a cam that has a nasty lope with good power . i have the a4 trans. dont really have a lot of money to spend on it so what do yall think i should go with ? thanks
Old 02-01-2010, 04:43 AM
Ed Curtis's Avatar
Ask for Mike at New Era Performance Parts
Old 02-01-2010, 05:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Originally Posted by Ed Curtis
He asked a question, not for a sales pitch....
If you want a nasty cam, there is no way you are going to want to drive it on the stock converter.
Factor in cost of converter which can be anywhere from 500-900$. You are going to want a drivetrain that supports it as well, so there are springs and pushrods (200$+) at minimum there. If you dont plan on installing it yourself go ahead and factor about another 350-500$ there.
When you say "Nasty" do you just want a lopey idle with no go? Or are you looking for nasty as in all out performance and lope is a bi-product from it. Don't get a cam for lope. It will be un-impressive when it gets cut by a stock v6 mustang.
Are you wanting to track this car or just be cool and have a cool sounding car? Hope you have a little money to spend. Seriously, don't go big. Low 230's with a 10° overlap would be as much as I would put up with in that car.
Old 02-01-2010, 05:43 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Oh yeah, tuning...$$$$ You will need it at that point. The wilder it gets the harder it will be to tune.
Old 02-01-2010, 06:02 AM
ls6firebird's Avatar
take your time and dont go cheap. i spent a little over a month researching different cams on here. i ended up ordering an ms4 from texas speed last week. the ms4 has a nasty idle, and i hear it makes good power....im about to find out. i started with texas speed, went down the list of cams, typed them in youtube, and looked for cars with similar exhaust setup as mine to get an idea of sound. after looking around i went back and ordered from texas speed.
Old 02-01-2010, 06:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Those MagicStick cams arent for everyone though. If you have never driven a cammed and stalled car I suggest you do that as well.
Old 02-01-2010, 07:00 AM
20ws601's Avatar
[. dont really have a lot of money to spend on it so what do yall think i should go with ? thanks[/QUOTE]
All cams cost about the same unless you find one you want used....the money is in the details....springs, push rods, oil pump, retainers, install, and the tune of course...you def dont want to skimp on the tune.
Old 02-01-2010, 12:01 PM
i am planning on getting a stall convertor around 4000 just looking for a good sounding cam but makes good power just looking for a sugestions on a cam and valvetrain. i had a carbed car with a big cam and stall and all and it was just a drag car mid 8 in the quarter just not to sure with this ls1 car cause it will be used for street to. i will be doing the work my self
thanks
Old 02-01-2010, 12:57 PM
transamfreak01's Avatar
if you are going with a 4k stall i would look for something in the 23x range. itll make great power and be driveable imo. what else is done with the car?? and what are the goals???
Old 02-02-2010, 02:39 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
thanks
Theres some good info to work with there! Sorry I cant comment more I have to head out to work, but you sound like you know what you are after. 4k stall is MS3-4 material right there.
Old 02-02-2010, 06:42 AM
Black 99 Bird's Avatar
Take a look @ LG Motorsports G5 series cams. I am sure they have something you would like with good driveability. I have the G5X3 on a 114, but maybe you would like it on a 112 for a chopier idle.
Old 02-02-2010, 08:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
...as far as a different LSA goes you will only get +1° more for every one you go down.
like say you have 114 with 16° with a 113 you would have 17° and so on so forth.
Old 02-07-2010, 07:19 PM
thanks for all the info
