What cam to use
Old 02-03-2010, 01:48 PM
stewdy1's Avatar
Default What cam to use
I have stock bottom end 6.0 outta truck with 241 heads and ls1 intake
plan to spray 150 should I use el toro or t Rex cam 4l80e tranny with
whatever converter i need
Old 02-03-2010, 06:42 PM
XtraCajunSS's Avatar
The TRex will not be optimal with the 9.7:1 compression ratio but will be ok. I would recommend a custom grind for your application. I can put together a more nitrous friendly combo for you if you are interested. Shoot me a PM if you'd like.
Thanks,
Shane
