Can gaskets be re-used on a new crate engine?
Old 02-06-2010, 07:31 PM
Blorton's Avatar
Default Can gaskets be re-used on a new crate engine?
Not trying to be a cheapskate, but I was thinking that if a new longblock from gm is being used, and the gaskets have not been heat-cycled, they should be reusable. Is that right? I'm just thinking in terms of putting my ported heads and custom cam in a new longblock....
Thanks.
Old 02-06-2010, 07:43 PM
BaddBird's Avatar
The head gaskets may not have been heat-cycled but they have been smashed. Besides head gaskets you will also need new head bolts.
Old 02-06-2010, 08:54 PM
batboy's Avatar
Some gaskets might be reusable, like water pump and stuff like that. Head gaskets should never be used again though.
Old 02-07-2010, 07:48 AM
Blorton's Avatar
Thanks guys - that makes sense. I'll be using ARP's in the swap anyway.
Old 02-07-2010, 11:06 AM
01ssreda4's Avatar
All the factory metal gaskets are reuseable, like valley cover, front + rear cover, oil pan, and water pump if they are metal. Good luck
Old 02-07-2010, 11:14 AM
trans_am7935's Avatar
also u can reuse the intake manifold gaskets as well, just be sure that the new head is clean before putting it on.
