ls6cnc or 5.3cnc, 233-239 or t2
Old 02-07-2010, 08:11 AM
truckpuller468's Avatar
Default ls6cnc or 5.3cnc, 233-239 or t2
Just bought an 02 TA ws6 that had a dead hole in it. Tore it apart and ringlands were broke on number 5. While it is apart I decided I better do whatever hotrodding I'm gonna do since its really not that fun to work on. To make a long story short I have ended up with two sets of heads and two cams. One is tsp 2.5 5.3s and the other et stage III ls6's.. The cams are tsp233-239 on 113 the other is torquer v2 on 112. Between the cams which will idle smoother? I know u will tell me the stage III heads are to big for a 346 but how much low end will it really cost me? I've already mocked up the 233-239 with the stage III heads and I had valve clearance so that is not a problem. Which of the heads is more valuable because I selling whatever is left. Its an m6 with sock gears. Will be installing lt's,cai, and a tune. Not a daily driver, just a weekend driver. What kind of mpg hit will I take with these mods?
Old 02-07-2010, 08:17 AM
pharmd's Avatar
Good questions, I'm watching as well...
Old 02-07-2010, 01:26 PM
mcamarols1's Avatar
233/239, .595"/.603" Camshaft With Your Choice of Lobe Seperation.
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
1900-6500 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required
This camshaft typically gains approximately 50rwhp!
The Texas Speed Torquer 2 232/234 .595/.598 Camshaft With Your Choice of Lobe Seperation.
1800-6400 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required.
This camshaft typically gains approximately 45-50rwhp!
Straight from TSP website. I'm running the V.2 on a 112 lsa, and I love it!
Old 02-07-2010, 03:50 PM
Soooo...........?
Old 02-07-2010, 06:27 PM
teke184's Avatar
probably won't be a significant difference between the two cams.
what are the LSA on each?
as for the heads...tough call. the 5.3s will boost compression, the ls6 will likely flow better.
