looking for suggestions on porting and milling 317 heads or 241s on lq4
I have a lq4 complete long block That I am going to install a cam in. I want to up the compression from the stock 9.4:1 so I would like t oknow what would be best to have the stock 317 heads milled and ported or have a set of 241s I have laying arround ported? Which ever head I use I want to run it on the stock lq4 short block. I have heard the 317s are basicly the same as ls6 or 243 heads but with larger chambers.
This may not help much but i am having my 317's ported but not milled due to a different set up. I have seen a LOT of ppl on these threads port and mill there 317's, but i dont know how many have a set of 241 heads laying around.
I have the 241s laying arround because they came off of the 2002 ss in my sig when I swapeed them for PRC stage 2.5 5.3 heads. The 241s are nothing special just have smaller chambers to get the compresion up. Im wondering how milling the 317s affect the flow numbers on them even when they are ported.
2. Whats your final objective with the LQ4?
The Lq4 is going in a fox coupe mustang that weighs about 3k. Building it as street/strip car. I mainly want to try to get the compression to about the same as a stock ls1. Im not that concerned with Hp numbers but I want it to run strong 1/8th and 1/4 mile. I don't want the low compression to affect my cam choice. When I have a problem with the stock lq4 I will use the block to build a 370 or 408. I also plan to put a 150 hp of nitrous on it .
The car will be a stalled a4 with 373 gears. Fuel injected haven't selected a intake set up for it yet.
Hope it helps.
milling them to much will cause issues like bad valvetrain geometry if you dont take measurements, depending on cam tight piston to valve clearances and not to mention a weaker head due to excessive material being removed. not good if u plan on a 150 hit or better down the rd
Thats the case with the 317s to bring down your chamber CC to make a differece, there is only so much material you can take off around the chamber, you will have to take way too much of the deck and it will be very unsafe to run a head like this even with ARP studs you will encounter degradation with time and the heads can literally explode off your block. Specially if you are adding N2O or any other type of power adder.
Stock compression on the LQ4 is advertised as 9.4:1 but actually calculates to ~9.56:1.
Here is a stock bottom end LQ4 compression calc breakdown using stock LS2/LQ4/LQ9 Head Gaskets:
72cc - 9.47:1
71.06cc (stock 317 chamber) - 9.56:1
71cc - 9.57:1
70cc - 9.67:1
69cc - 9.77:1
68cc - 9.87:1
67cc - 9.98:1
66.67cc (stock LS1 241/853) - 10.01:1
66cc - 10.09:1
65cc - 10.20:1
64.45cc (stock LS2/6 243) - 10.26:1
64cc - 10.31:1
63cc - 10.43:1
62cc - 10.55:1
61.15cc (stock 5.3 706/862) - 10.66:1
61cc - 10.68:1
60cc - 10.80:1
59cc - 10.94:1
58cc - 11.07:1
57cc - 11.21:1
56cc - 11.35:1
I'm running some 5.3 heads on my LQ4 stock bottom end in my TA in my sig. Only mods on the heads was to put the factory LS1 intake valves in place of the smaller 5.3 valves. Chamber volume didn't change which put my compression right at 10.66:1. It's a stick shift car with a G5X3 114lsa cam and a 3.73 gear which is way too tall for the 28" slick I run and best to date on completely stock rear and stamped steel suspension was 12.2@119mph NA and 10.91@128 150 wet shot. Vid in sig of the 10.9 pass.
72cc - 9.47:1
71cc - 9.57:1
70cc - 9.67:1
69cc - 9.77:1
68cc - 9.87:1
67cc - 9.98:1
66cc - 10.09:1
65cc - 10.20:1
64cc - 10.31:1
63cc - 10.43:1
62cc - 10.55:1
61cc - 10.68:1
60cc - 10.80:1
59cc - 10.94:1
58cc - 11.07:1
57cc - 11.21:1
56cc - 11.35:1
I was asking because I have some Stage 3 317's on my 408 with 12:1 compression and Diamond flat tops. How much do they mill off to get 12:1? I want to run more than 150 on the jug.
With the 408 you are compressing so much more air than the stock 370 that you chambers can be a lot larger (milled less) and still net higher compression ratio. On my 404 with 61cc heads, dished pistons and valve relies om at 11:1... You might still be around 68-64cc chambers. I'm on my cell and don't have my comp ratio app on here to give you the exact cc of your heads
Goto wallace racing calculators, punch in your numbers and it will tell you what you have
Bore: 4.030
Stroke: 4.00
Head Chamber (cc's): 67
Valve Relief / Dome (cc's): -2
Gasket Thickness: .051
Deck Height: 000
Your displacement is 408.18 CID
The Compression Ratio is: 12.05
Now I understand why the OP should go with the 243's on his 370, gotta take to much material off the head to get the compression up. Thanks for the info
So would It be safe to assume that I'm ok to hit it with a 200-250 shot?
I'd think your heads could take the shot with no problem as long as your timing and a/f ratio are tuned for it, and to be safe I'd run 100 octane unleaded or higher when you plan on hitting it with that big of a shot(just dump in a few gallons on race day).
One of my frends is running a 346 big cam(25x duration) with dome pistons and big valve ported and milled 5.3 heads on 112 octane unleaded race gas... 14:1 compression 350 combo 2 stage wet/dry shots and his motor holds together
Just curious what is your dynamic compression ratio sitting at with your cam?
How do you figure out DCR?
