Crank Reluctor Wheel
Old 12-26-2003, 01:32 PM
Mr. B's Avatar
Default Crank Reluctor Wheel
Is the outer reluctor wheel (on the crankshaft) replaceable?
If two of the teeth were slightly "peened" in shipping, but the wheel appears straight, what can be done to remedy this?
Old 12-26-2003, 04:33 PM
LOnSLO's Avatar
It is a very simple job for any machine shop to replace one. Most reluctor wheels are not perfectly straight, but if a couple teeth are bent, just go ahead and get a new one.
Old 12-26-2003, 05:14 PM
Mr. B's Avatar
Can you order just a reluctor wheel w/o the crank?
How is it removed? Drilled out or pressed off?
Old 12-26-2003, 07:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
If it's a new crank,The supplier should replace it free of charge.That is what I would do to be safe.
Old 12-26-2003, 08:03 PM
Mr. B's Avatar
Slowhawk.. it's a used crankshaft, which I wanted to use to make it easy to redo my bottom end without having to disassemble my stock shortblock.
I can't find anything about the procedure to replace it.. I did see there is a machine which is used by machine shops, but nothing concrete on how and if I should even bother- UPS will probably have to address this.. they are fu<kin' morons, the way they treat packages..
Old 12-26-2003, 08:38 PM
Mr. B's Avatar
I found it..
How the hell is it removed???
Old 12-27-2003, 06:41 AM
Scott Turvey's Avatar
Heat and a specialized tool made specifically for this/
Old 12-27-2003, 09:18 AM
LOnSLO's Avatar
They are just pressed on, then tack welded to hold it in place. Simple as pie.
Old 12-27-2003, 01:14 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Does the wheel have to be aligned a specific way as related to the crank?
Old 12-27-2003, 01:17 PM
strokedls1's Avatar
I had a local machine shop degree a stock crank and use that as a template to press on one on my lunati crank. Just heat the reluctor and press it into place. I then had it tack welded in two places before going back to the balancer. Cost was 50 bucks to get the reluctor put on. Process could be reversed to get it off.
Old 11-03-2007, 03:59 PM
cjg454ss's Avatar
where did you get your reluctor wheel. spdc is on backorder till jan 08
Old 11-04-2007, 06:17 AM
Firehawk441's Avatar
I've gotten them from Callies in the past.
Quick Reply: Crank Reluctor Wheel
