HELP !! LS1 H/C swap(Block Issue Also =s !!)
99 camaro z28 LS1 FULL WEIGHT
17" x 9.5 255 45 front
18" x 10.5rim's6 315 45 rear
6 speed, .373 gears, stage 4 Clutch Master 6 Puk disc
MSD wire's
Otherwise BONE STOCK:
Looking at TSP Head's & Cam Package
Precision LS6 2.5 heads 64cc
MS4 114
tsp ls6 ported oil pump
ls2 double roller timing chain
fast intake 92 / N.W 92 tb
TSP long tube headers 1 7/8" + (o2 bungs) + 3"cutout + Magnaflow
ASP Harmonic Balancer AC & Accessory Belt + Arp Bolt
PUSHRODS LENGTH ???? CANT FIGURE ??
WHAT TO DO WITH THE STOCK BLOCK =S ??
INJECTORS size & Brand ..... ??
Expected Dyno Number's ???
How Durable is the setup were should i expect the wear & tear ??
Got enough talk's from here & there but now it's time to BUY NOT Guessing.
thankyou in Advance
MSD wire's
MS4 114
thankyou in Advance
What questions are you asking how much power it will make. You can use the stock pushrod length it will not change.
And what is the block questions?
With that cam you will have to have someone tune it and you need to get valve springs good up to 650 lift
the package already includes spring up to .660 lift with titan retainer's
what are my option's for the block ??? should i swap to an LS3 .... or 383 rotat Assem ??
would help to know the best durable sugesstion's =)
thank you
If your looking for that combo, I hate to say it fella. But look into a rear if you don't have one. The 10 bolt wont last long at all.
36# injectors with a fuel pump should do you about good. If you plan on spray in the near future, then bump up to 42#ers to be on the safe side. As for pushrods, you should always measure.
The MS4 on a 114 is going to be a really tight fit but it can be done. You'll make somewhere in the 450whp region. But you are going to need a really good tuner to break 450 though. With how high you are going to want to spin the motor, I would also suggest rod bolts. Other than that, that is about as tough as you can make the stock motor without forging it. Just remember the MS4 is a max effort cam and you are asking about how reliable it will be.
its going to need a fuel pump and injector for sure and the 10 bolt will be inpieces soon i just recently finished a 383 build with ported and polished ls6 heads and the ms4 cam not sure of the power though the local tuner darren blanchard dosent have a dyno yet but seems to be the best in louisiana in my opinion and all of my friends. We are hoping by the time he get the fast 92/92 combo and the n20 that darren will have a dyno so we can see sum numbers. but wer are guestimating around high 500s. i think your asking to much out of the stock cube 346 without dumping some serious money into it
MSD wire's
MS4 114
Well....The stage 2.5 heads wont clear that cam because the bigger 2.5 valve cause PTV issues.... BTW the LS2 chain is a single roller but stronger than the LS1 chain it replaced.
More than likely 7.4 but you should still measure. BTW OEM are 7.385 but you will need slighyly longer to make up for the smaller base circle on the cam.
Huh? How much cash do you have to drop
Ford SVO 30#'s (Red tops) flow 36# at our fuel pressure and used go for around $125 on here. Some 42's would work too. Stock fuel pump is fine at your power.
440ish
Ultimately it is how hard you beat on the car....Well I don't see year but if you are 01-02 you have a little bit better rod bearings so the bottom end holds better at high RPM's so that helps. You will be spinning that cam to 6800-7000k One reason I picked my cam is because it peaks earlier and didn't want to worry about spinning a bearing or valve float issues. Those are pretty intense high lift lobes so count on at least pulling a few springs and checking pressure very 10-12k
thankyou in Advance
MSD wire's
MS4 114
440ish
thankyou in Advance
you should call matt at tsp he will answer all your q's after all it is his stuff you want to buy why would you ask any one eles?
i have there prc 215 heads with a trqv3 ls6 intake and 36 injectors and made 440 to the wheels and 423 tq
Would like to thank you all for your advice =) & sugesstion's .... I spoke to tsp -Matt for a shipping qoute for the Item's & i wanted a push from the people who have seen it done .... soo long ls1 ..... time for an LS3 i suppose =D .... will surely try posting up the update's .....
Not a Dyno Racer ..... A street monster is my build .... should i just send the PCM to texas speed ..... or not be worth it without the car ??
