5.3l compression
Old 02-16-2010, 09:05 AM
dreambird's Avatar
Default 5.3l compression
I was wondering if anybody new what the compression of a 5.3l truck motor would be if 4.8l pistons were installed in it?
Old 02-16-2010, 10:24 AM
99LS1Bird's Avatar
as far as ive read it shouldnt change at all the only difference in the 4.8 and 5.3 short block is the crank(stroke length). i think the heads are different though the 4.8s should make a good bit more compression
Old 02-16-2010, 11:20 AM
dreambird's Avatar
I have read before that the 4.8l engine has flat top pistons and the 5.3l has dished pistons but I have not seen how much it would go up with the 4.8l flat tops in the 5.3l with the stock 5.3l heads
Old 02-16-2010, 11:26 AM
batboy's Avatar
You are correct, the 4.8 piston is flattop and the 5.3 is dished. The truck guys often swap in 4.8 pistons into their 5.3 engines to raise the CR. I can't remember how much, but I think it was either a 1/4 or a 1/2 CR point. Check out the performance truck part of the forum, I know I've seen this over there.
Old 02-16-2010, 11:36 AM
dreambird's Avatar
thanks alot for the info I am trying to decide if it would be better cost wise to put the 4.8l pistons in or have the block bored to run 5.7l pistons . I will check out the truck forum as you said thanks again!
Old 02-16-2010, 12:33 PM
5.3LJimmy's Avatar
Compression will be raised from 9.5 to 10.3:1. 5.3 and 4.8 both use the same heads.
Old 02-16-2010, 02:30 PM
dreambird's Avatar
thanks alot for the great info!
Quick Reply: 5.3l compression
