Milling TEA 1.5s with X1
Im wanting 11.1 compression with those heads and cam and Im using stock GM head gaskets. How much do I need to mill to achieve this? Im thinking .015. Can I use my stock length rods. Im also running Yella Terras, Will this affect lifter pre-load? Thanks for any info.Jason
Are they 5.7 heads, or 5.3 heads? You'd probably need to mill .030" on a 5.3 head to ge the CR that high. With .030 milling, exercise care with the X1 cam. There may be P/V issues with lifting that high. Clay or verify the clearance with that cam and .030 milling. Period. Some have done it without any issues and some have smacked pistons and broken valves. Check it, check it, check it.
Stock gaskets are fine. If you only want to mill .015, you can use a Fel-Pro gasket to raise the CR a bit since they are slightly thinner than stockers. You can use the stock PR's, but anytime you change the relationships in the valvetrain geometry, you need to compensate it somehow. Shimming the rockers would be the easiest because the next shorter PR is a 7.350".
How do you like your YT's? I'm contemplating a purchase.
LSX Mechanic
A stock, unmilled 5.3L head will NOT yeild 11:1 right off the bat. Milling .015 will put you @ 11:1 w/ a 5.3L head.
J2KSS, w/ the X1 cam do not mill below .025 for safety. If you're running a 5.7L head, milled .025 and run an 02 Multilayer gasket(.005 thicker than standard). If you're going to run 5.3's, mill .015 and run whatever gasket you'd like...
Josh
Josh
Make sure to check clearances if you do mill just to be on the safe side.
Attached are 2 posts about a problem someone had that was supposed to be an OK setup as far as clearances are concerned.
https://ls1tech.com/forums/generation-iii-internal-engine/111243-p2v-clearance-mti-stage2-ls6-x1.html
https://ls1tech.com/forums/generation-iii-internal-engine/114365-mti-stage-2-ls6-x1-clearance-problems-pro-s-inside-please.html
